跳转到主内容
加入维修社区 - 创建账户
Brother 打印机的维修与拆解指南。
Brother MFC-8460N Printer Error
My brother printer always displays this error when i power it on..it lights a red blight then displays this error message..Machine Error. Contact Technical Support
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@onneilecas43557 following the MACHINE ERROR you should see another error code appear on the LCD. If not then check to see if this will tell you how to possibly finding the real error code. Just check 8.4.16
Now, if all you are getting is the The "Machine Error. Contact Technical Support" message then this is very generic for a mechanical failure. Could be the fuser or even the scanner malfunction. You would have to work through the troubleshooting section of the Brother Fax MFC 8460 Parts & SM for your printer.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Onneile Casius william 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 114
