跳转到主内容
加入维修社区 - 创建账户
Realme 9 是 Realme 于 2022 年推出的一款中端智能手机。
My phone not speaker
Mere phone me avaj nahi sunai deti hai
Update (04/14/26)
  1. Mere phone avaj nahi sunai deti hai
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论:
Power button dabane me nhi khulta
由完成的 分享
Display remove in phone
由完成的 分享
Mere ka mic kaam nhi karta
由完成的 分享
Speaker mein awaaz bahut kam aata Hai
由完成的 分享
添加一条评论
1个答案
@princekuma96001 @rohitkewat no sound or low speaker volume is usually caused by clogged mesh, an audio setting, or a failed speaker module. Since no one mentioned which speaker is low volume or not working, you have to determine if it is the earpiece speaker or the speakerphone one. Make a call and toggle the toggle Speaker on and off. If the call is quiet against your ear but loud on speakerphone, the top earpiece is the problem. If music, ringtones, and speakerphone are all quiet, focus on the bottom loudspeaker.
Also clean the speaker mesh with a clean, dry, soft-bristled brush. Do not poke anything into the mesh holes as you could damage the speaker.
Next make sure that this is not a setting issue. Turn off Bluetooth to make sure the audio does not accidently gets routed to any previously used earbuds or speakers etc. Next go to Settings ==> System/Additional Settings ==> Accessibility ==> Hearing and make sure the Audio balance slider sits in the middle. Then open Settings ==> Sound & vibration and raise Media, Ring, and Call volumes separately. Now play a video or audio and see if that made a difference.
If not then you know the issue is not a settings issue but it is hardware related. You will have to replace the speaker module. Since iFixit does not yet have a specific guide for this, use something like this video The bottom speaker is shown at 4:22min and you can see the earpiece speaker in the last minute after removing the main board. It is the part in the top center position.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person who has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Prince Kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 47
总计 443
