跳转到主内容
加入维修社区 - 创建账户
Itel L6502,又名 Itel Vision 1 Pro,是一款于 2021 年 1 月发布的入门级智能手机。它配备了一块 6.52 英寸的大型 HD+ 显示屏,搭载基础的四核处理器和 2GB RAM。通常运行经过优化的 Android 10(Go 版本)操作系统。
How to fix the charging system
How to fix a charging system port
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
5条评论
how to fix charging port
完成的
@zai6292 See the charging port replacement video posted in @oldturkey03's answer.
完成的
Charging system is disturbing me I would like to repair
完成的
How to repair the charging point
完成的
Show me Counties the screen
完成的
添加一条评论
2个答案
最有帮助的答案
@mainalyton you are not telling us what the issues are (I assume it is not charging) nor are you telling us what you have already checked and tried. Of course, you always check your charger and your charging cord. Make sure you have the proper voltage and that your cable is in good working order.
Next, you want to check your charging port. Make sure that it is clean and does not have bent pins. Use a few puffs of canned air to clean out any pocket lint etc. If all of that is okay, then a charging issue can be caused by a bad charging board, a bad battery or a bad cable from the charging board to the mainboard. I would start by replacing the battery and the charging board at the same time. That way you only have to open your phone one time.
Since iFixit does not yet have a guide for that use a combination of this video for the charging board, as well as this video for the battery.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 1
添加一条评论
Open the phone and remove a panel and use a hot air station to replace a pot
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maina Lyton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 62
总计 552
