跳转到主内容
加入维修社区 - 创建账户
Toyota Vitz 是一款小型掀背车,于 1999 年作为 Toyota Starlet 的继任车型首次推出。它在国际市场上以 Toyota Yaris 或 Echo 的名称销售。目前 Toyota Vitz 已推出 4 代车型。
Sparkplug engine car shaking
Only my right sparkplug turns black every week and then my car starts shaking when I drive?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@yahvehhuisraad this will depend what the spark plug face actually looks like.
If it is black with soot, it is most likely because of a bad air/fuel mixture. To address this, we will need to know the exact year and model for your Vitz. Make sure you have the right spark plugs installed.
If it is black and full of oil, you are burning to much oil which can be caused by bad valves or bad piston rings etc. For that you would need to start with a compression test or better, a leak down test.
This "then my car starts shaking" is because your spark plug does no longer fire properly (if at all ) and thus your engine performance goes down, your car will have poor fuel mileage and poor idle etc.
Let us know what you find out.
这个答案有帮助吗?
得分 1
添加一条评论
When compression is low, the spark plug will usually become coated with a black, oily deposit.
But it could be something else. I'd swap the sparkplug and wire and see. If the problem now resides in a different cylinder, then I'll need to replace the wire and sparkplug. The ignition coil could also be the issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yahveh Huisraad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 152
