跳转到主内容
Release date: Jan. 24, 2008; 8MP, 3x Optical Zoom, Built in optical image stabilizer system and Face Detection software; DIGIC III Image Processor.
13 个问题 查看全部
water damage, won't turn on
Hi somebody,
My canon was dunked in water and after drying it out the camera makes no function...
how many fuses are and where they are?
Thaks,
Vidma
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Have you disassembled and cleaned it yet?
完成的
Hi oldturkey03, Thanks for the very fast and full-scale response!
I"ll try a bit later.
vidma
完成的
the FUSE was not faulty,
I cleaned with alcohol, shorted the SWITCH on battery door, but still nothing.
Think stray current made more serious damages :(
完成的
vidma, try to clean the logic board with with isopropyl camera. There are a few more fuses on the logic board. Check all those for continuity.
完成的
Thanks oldturkey03, but how to find them, could you send me service manual with repair instruction and diagrams?
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
vidma, the image will show you where the power fuse is located. Just remember that with water damage, a good cleaning with isopropyl alcohol is a must. Otherwise, you run the risk of corrosion failure later on. Here are more reason why your camera may not get any power:
"If electrical conduction is not found:
• FUSE is blown; replace it with a new one.
If the FUSE is not faulty:
• MAIN PCB Assembly excluding the FUSE is faulty
• OPERATION FPC Assembly is faulty
• TOP COVER UNIT is faulty
• BATTERY COVER is damaged.
• DETECT SWITCH(MAIN PCB assembly) is faulty"
Hope this helps, good luck
这个答案有帮助吗?
得分 1
2条评论:
Hi oldturkey03 I replaced the main then also cam is not getting on.where can I get all cam spares.plz help
完成的
canon sd 1100 got dunked in juice , cleaned with ip also replace fuse 1001 then also not getting 8n plz help.
完成的
添加一条评论
添加你的答案
vidma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 2,152
