跳转到主内容
加入维修社区 - 创建账户
PS5 游戏机于 2020 年 11 月发布,其视觉效果大幅升级,并配备了创新的全新 Dualsense 控制器。太空时代的黑白配色方案与过去的 PlayStation 设计大相径庭。
Pss5 not recognizing discs
Every time I turn on my PS5, the disc drive runs but says it does not recognize the disc. I have already tried replacing the disc driver laser, KEM-497aaa. The model is CFI-1115a.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Usually it is the laser, but it could be way more (drive board, other components on there, etc.).
I recommend to try with a new drive, and see what happens.
Note: Always transfer your original board (from the OLD drive to the >>> New drive)!!!
Can you let us know how that goes?
Thanks!
这个答案有帮助吗?
得分 1
5条评论:
I have already tried replacing the part 3 times that’s why I’m looking for any other ideas to try and help
完成的
Hi! Did you replaced the whole drive 3 times? Or just the laser? Thank you!
完成的
@dan0 I replace the whole drive!
完成的
okay, then I'm afraid it's related to either the motherboard or the PCB. Is there a way for you to test them (and do you have soldering experience)? If the PCB is broken, it would be difficult to fix as you cannot marry a new PCB to the motherboard. Otherwise I recommend to check with a local repair shop. Sorry.
完成的
Well, you can't re-pair the boards unless you happen to be Sony and have all of their proprietary pairing software. You might also try moving the component that actually pairs the drive PCB to the motherboard, but last I checked, that's not easy to do and requires microsoldering to pull off (But hey, try it if you want!). You could also try to figure out if there's a specific component on the board that's being problematic and replace it.
完成的
添加一条评论
添加你的答案
MoJama 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 25
总计 101
