跳转到主内容
加入维修社区 - 创建账户
Sony Cyber-shot DSC-W55 于 2007 年初发布。与之前机型的 510 万像素摄像头相比,它升级到了 720 万像素摄像头,并拥有 56 MB 的内置内存。
My Lens does not focus.
My son dropped my DSC-W55 and now while focussing, I can see blurred images. But if I gently push the lens from outside, I can focus clearly. But if I try autofocus, then due to the lens movement, the lens defocuses again. I need to repeat the 'Push' action every time I need to click a picture. Can someone Help me get it resolved? I took it to the Repair centre, they wanted me to change the entire Lens unit, but I believe there should be some fix, other than replacing the unit. THANKS !!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Would you be comfortable to disassemble your camera right down to the lens block itself?
由完成的
Yep. I would be happy to disassemble if I could get it fixed. I wanted to check if there was any minor problem.
由完成的
添加一条评论
2个答案
已选择的解决方案
TKS, download the service manual from here. Scroll down to Service Documents and click on the links. It will show you all the details and should help to trouble shoot. Hope this helps,good luck.
这个答案有帮助吗?
得分 1
1条评论:
Minha máquina não liga mais e parou do nada. O que pode ser?
由完成的
添加一条评论
最有帮助的答案
Hello,
Your camera uses several other factors when auto focusing including infrared or sonar. It sounds like when your son dropped it, You may have jarred one of these sensors. Replacing the lens is an option that i would use last.
My suggestion to you. Manually focus the lens to extend then gently wiggle it back and forth to allow it to recenter in the tube. It retracts and may have been shaken off track.
这个答案有帮助吗?
得分 2
1条评论:
@Gametech. Thanks .. I will try the suggested fix. But do you want me to open the Camera and do this?
由完成的
添加一条评论
添加你的答案
TKS 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 72
总计 9,890
