Remove alternator from engine
I have alternator broke but can't find space to pull the alternator out
@donaldmart53225 here are the instructions for the Generator Removal from the workshop manual. If there is anything in the way etc. you want to go ahead and post some good pictures of your situation. That way we can see what you see and hopefully find a solution. 在已经存在的问题里加入图片
@donaldmart53225 all the wires are loose and your removed all the bolts etc.? Where are you stuck? You normally are supposed to drop the engine. Take a look on here to see how to try and do it without dropping the engine, or on here where you drop the engine.What a PITA
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 29
总计 201
1条评论
Alternator is loose but I can't get out frustrating
由 Donald Martin 完成的 分享
