跳转到主内容
加入维修社区 - 创建账户
2020 年款 ASUS G15 G512LI 的维修与拆解指南。该笔记本电脑由华硕生产,主打入门级/轻量化游戏体验。
Screen went totally black
I got flickering in my screen and I powered off normally. When I opened back the screen was full of stripes. Rebooting once the screen went full black. I thought the display was the issue and tried changing it but no good even the ASUS authorised service centre said no issues in display screen.
By digging deep they said something went wrong and I need to replace the mother board. Is there any way to fix this
On the good part I can connect to external monitor by this way I can use my laptop
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@kavin41097 this "On the good part I can connect to external monitor" makes me wonder why you would need to change the motherboard. This sounds like an issue that is related to your LCD and not the processor. Looks like your laptop has 2 GPUs. One is the integrated Intel, which is combined with the CPU, and a discrete Nvidia which is separate. The Intel will work until your computer loads the OS (Windows I assume) which will then direct the video to the Nvidia processor. That means you should see a picture right up to the point where Windows is loading.
Check you LCD screen and the display cable. Also, check the display connector on your motherboard. Post some well focused pictures of that with your question. It will help if you can tell us what exact motherboard your computer uses. It is printed on the board itself, but maybe on the underside.
Looks like the display cable is part number LVDS Flex Video Cable 14005-03070000
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kavin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 213
