跳转到主内容
加入维修社区 - 创建账户
保时捷 Cayman 和 Boxster 是保时捷生产的中置发动机双座跑车。这是针对第四代保时捷 Cayman 和 Boxster(即 718/982 系列)的维修与支持指南。
check front right dipped headlight
my 2014 porsche 981 718 cayman check front right dipped headlight appear on my dash. how can i fix this myself and what is the correct light i need to replace? thank you 🙏🏼so much.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@speedbumpla looks like you need to remove the headlight to get to the bulb. Here are the instruction for the 2013 2016 Porsche Cayman Boxster Base S GT4 981 Headlight Removal As for which bulb, I would wait until you have the old one removed then get the replacement. That way you know that it is the right model for sure. Those should be Philips - Diamond Vision H7 Halogen HID Bulbs but again, wait until you have the old one out. If you need more or different information you can now get the complete workshop manual from this page Porsche 718/982 Series under the Documents header
这个答案有帮助吗?
得分 1
添加一条评论
You should check whether your headlights are on normally.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
speedbumpLA 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 43
总计 281
