跳转到主内容
加入维修社区 - 创建账户
No bootable device showing
Insert a boot disk and press any key is saying and not showing hp icon
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@arfatshaik73507 sounds like your computer can either not find / read the hard drive (or SSD) or the files on the drive are corrupted (OS failure). You need to try and access the BIOS on the computer and see if the BIOS can see your hard drive. If it does not it is most likely a failed drive. To repair that you would have to replace the drive.
If it can see the drive then it is most likely an issue with the MBR (OS failure). We need to know if this is a HDD or an SSD
To get into the BIOS just press F10 repeatedly at startup.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Arfat Shaikh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 27
总计 190
