跳转到主内容
加入维修社区 - 创建账户
Microsoft USB 力反馈游戏摇杆控制器。 1998 年 8 月 X05-92622
Auto Center Weak in One Direction
Recently picked one of these up used (only way to get them today, obviously), and the auto-centering function seems to work very weakly when I pushed the joystick forward, or not at all. I'm assuming there is some mechanism inside that needs to be cleaned/fixed/replaced. Has anyone done a teardown of this base, or repaired the Auto Centering/FFB mechanisms inside? I'm assuming most of the parts inside could be ordered and/or 3D printed, but I don't know where to start.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@dantehchad take a look at this teardown You may have some bad pots that may need to be replaced as well as cleaning the gears, motors, etc. Also, try the ForceTest.exe from here or the one from here, and see if you can configure your joystick to give you a better auto center feel.
While you work on your Joystick, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan teh Chad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 37
总计 260
