跳转到主内容
加入维修社区 - 创建账户
HP Probook 4330s 笔记本电脑配备第二代 Intel Core i7/i5/i3 处理器或 Intel Celeron B810。HP Probook 4330s 配备 13.3 英寸高清显示屏、Mobile Intel® HM65 Express 芯片组、蓝牙 3.0、Wi-Fi、四个 USB 2.0 端口、一个 VGA 端口、一个 HDMI 端口和高清网络摄像头。
How to fix boot error problem
Video to solve this problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi @aashishnana67
You have asked the same question 3 times now and had responses to the first 2 questions asking for more information so relevant answers could be provided.
1st question
2nd question
You have not responded to their requests for more information.
Please stop asking the same question and respond with more information as to what the exact problem is.
Moderator.
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
A boot error on an HP ProBook 4530s usually comes from incorrect BIOS settings, a failing drive, or corrupted boot files. First, enter BIOS (press F10 on startup) and ensure the hard drive is detected and set as the first boot device. If detected, run HP Diagnostics (F2) to check HDD health. If the drive fails tests, replace it. If the drive passes, boot from a Windows installation USB, choose Repair your PC, then run Startup Repair. You can also use Command Prompt to run bootrec /fixmbr, /fixboot, and /rebuildbcd. Update BIOS if needed. If errors persist, reinstall Windows.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aashishnana 67 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 32
总计 181
