How to fix boot error in ProBook 4530s laptop
A boot error on an HP ProBook 4530s usually comes from incorrect BIOS settings, a failing drive, or corrupted boot files. First, enter BIOS (press F10 on startup) and ensure the hard drive is detected and set as the first boot device. If detected, run HP Diagnostics (F2) to check HDD health. If the drive fails tests, replace it. If the drive passes, boot from a Windows installation USB, choose Repair your PC, then run Startup Repair. You can also use Command Prompt to run bootrec /fixmbr, /fixboot, and /rebuildbcd. Update BIOS if needed. If errors persist, reinstall Windows.
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 20
总计 20
Please give us more information on what you mean by a boot error. Are you getting an error message? Does the laptop not boot? Does it see the drive? Be specific about what the laptop is doing or not doing so we can help. As it is, we don't have enough information to assist you.
由 Jerry Wheeler 完成的
