跳转到主内容
加入维修社区 - 创建账户
HP ProBook 4440s 的维修指南与故障排除。ProBook 4440s 配备 14 英寸屏幕和 Windows 7 操作系统,可通过型号 C6Z33UT 进行识别。
How fix boot error in probook 4530s modle
How to fix boot error in probook 4530s
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi! Do you get an error code..? Where does it goes wrong? In Windows or in the POST? Do you get a diagnostic screen from Windows? Can you share some pictures with us? Thank you!
由完成的
添加一条评论
1个答案
最有帮助的答案
A boot error on an HP ProBook 4530s usually comes from incorrect BIOS settings, a failing drive, or corrupted boot files. First, enter BIOS (press F10 on startup) and ensure the hard drive is detected and set as the first boot device. If detected, run HP Diagnostics (F2) to check HDD health. If the drive fails tests, replace it. If the drive passes, boot from a Windows installation USB, choose Repair your PC, then run Startup Repair. You can also use Command Prompt to run bootrec /fixmbr, /fixboot, and /rebuildbcd. Update BIOS if needed. If errors persist, reinstall Windows.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aashishnana 67 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 141
