跳转到主内容
加入维修社区 - 创建账户
Infiniti G 系列是日产旗下豪华汽车品牌 Infiniti 生产的一系列紧凑型行政/入门级豪华运动轿车,生产年份为 1991–1996 年和 1999 年至今。
Why is one headlight dim
One headlight dimmer then other even with new bulb
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would check the ballast, especially if this is a HID headlight-equipped car. Those ballasts can and often do go bad after several years, and especially after a new lamp is installed confirms the ballast is failing. That said, usually, if one is going out, the other isn't far behind, so I would do both while you are there. It's generally a when, not if issue with HID headlights.
Without the year of the car we can't help you find parts, so look up your car's model and put HID ballast in the search term.
这个答案有帮助吗?
得分 0
1条评论:
Is the lens / cover cloudy on one side? The clear one may have been replaced.
由完成的
添加一条评论
添加你的答案
Sui 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 178
