跳转到主内容
加入维修社区 - 创建账户
Keyboard keys issue Some keys automatically pressed.
When I press one key on my Dell Vostro 15 5568 laptop keyboard, other keys are also pressed automatically. For example, when I press the Alt key, 0 and 1 appear, and when I press Num Lock, the keys Q, W, E, and R are triggered.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@ahadraza this looks and sound like a failed keyboard. This model integrated the keyboard into the top cover (palmrest) and it is the best way of replacing the keyboard. Yes, you can also try to remove the original keyboard from the palm rest, by breaking of the plastic rivets that connect the keyboard to the palmrest. After that, you would need to install a replacement by substituting small screws for the plastics rivets. You will also need additional adhesive. Using screw's and adhesive is not always sufficient to provide a stable keyboard.
Personally I would install a palmrest with the integrated keyboard. It's a bit more expensive but a whole lot easier to replace and it will look and function professional. or now, you can always use a USB keyboard and let us know if that functions properly.
Use the Vostro 15 5568 Manual page 42, to work on this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ahad Raza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 113
