跳转到主内容
加入维修社区 - 创建账户
HP Victus 系列游戏笔记本电脑的维修指南和拆解信息。
Mouse pad is stuck
My mouse pad is stuck and the left click is constantly pressed which makes the pad unusable
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@ghost47490 start off by checking and adjusting the settings for your touchpad.
Through Windows Settings:
  • Press Windows key + I to open Settings.
  • Go to Devices and select Touchpad from the left-hand menu.
  • Adjust Touchpad sensitivity using the dropdown menu.
  • You can also customize gestures, scrolling and zoom settings here.
Through Control Panel:
  • Open the Control Panel.
  • Go to Mouse.
  • Click the Touchpad tab (this may vary depending on your driver) and find the options to adjust sensitivity or other settings.
If none of that will make a difference I would consider removing and checking the touchpad for and physical damage and/or replacing it. Use the HP Victus Maintenance And Service Guide and on page 59 it tells you how to work on it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ghost 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 46
总计 851
