跳转到主内容
加入维修社区 - 创建账户
高尔夫五代(Golf Mk5)于 2003 年秋季在欧洲推出,并于 2004 年初进入英国市场。在北美,大众在 2006 年引进该车型时,重新启用了 Rabbit 这一名称。
How to lower emmisions?
I have changed my oil ( not filter ) and put a cleaner in a couple of days before the test.
I plan to inflate all my tyres, get a different fuel cleaner ( Dipetane ), change my oil filter & air filter. What else can I do? I'm new to doing stuff myself.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@mary58088 did your Golf fail the emissions test? Make sure that your exhaust does not have any leaks, inspect the EVAP system (like broken charcoal canister etc.), check for any vacuum leaks. Changing your spark plugs is a must. You have not told us if your Check Engine light is on. It will also help if you can tell us the specific year and engine size for your Golf.
这个答案有帮助吗?
得分 0
1条评论:
Hi, I failed my NCT test in Ireland due to high emissions that’s all, nothing on my dashboard. Thanks for the tips, it’s a 2007 Engine: 1390cc.75hp.
由完成的
添加一条评论
添加你的答案
Mary 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 203
