跳转到主内容
加入维修社区 - 创建账户
Tecno Spark 8 Pro 于 2022 年 1 月 4 日发布,配备 6.6 英寸显示屏和三摄摄像头配置,有四种颜色可选。
How to change the screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 12
5条评论:
完成的
@alparslan73752 same way as explained in my answer
完成的
My power Techno button Spark 9 had issue
完成的
@ajiwoginnin what kind of issues?
完成的
完成的
添加一条评论
2个答案
The screen has three flex pin 1st you should open back cover with tweezers and open the screws use something like razor to make space to separate screen clean the frame and put new screen each flex at the pin
这个答案有帮助吗?
得分 0
添加一条评论
@manuel61041 since iFixit does not yet have a specific guide for this phone, Use something like this video to replace the screen. Replacements are readily available at many online stores. You also want to make sure you get the screen already assembled with the mid frame. It makes it a little easier and it does not cost much more.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Manuel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 708
