跳转到主内容
加入维修社区 - 创建账户
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南、拆解和故障排除信息,它是 DualShock 系列的继任者。可通过型号 CFI-ZCT1W 和主板型号 BDM-010 进行识别。
Options and Camera Button PCB replacement
I swapped my analog sticks with TMR sensors, and in the process of doing so I accidentally clamped down on the area of the PCB where the options and camera buttons are. The little gold domes are now completely smashed down and don't work. Is there a way to replace these without having to get a whole new board? If so, what are they called, and where can I get them? Thanks!
Update I kinda fixed my controller....I figured out you can heat the PCB from the back of the buttons using a hot air station to remove them (I used 350C and fan speed 4.5). I stole the controller reset button and put it in place of the "options" button. It's worth noting that if one of these buttons is removed from the PCB, it'll read as always "pushed"....so you have to put the bad button back on the spot you took the good one from. So, long story short, I can't take screenshots with this controller anymore, and if something weird happens I don't have the option to hit the "reset" button, but it's now usable again because my "options" button works great! Hope this helps anyone with this issue.....I'd still like to know if anyone can steer me in the direction of getting some new buttons though!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi! Is it possible to upload some photos regarding this?
在已经存在的问题里加入图片
Thank you!
完成的
Photo uploaded. Thanks!
完成的
添加一条评论
1个答案
最有帮助的答案
Hi Larry!
Thanks for posting a photo!
Okay, if you want the full functionality back, you do need to replace the buttons for working ones.
Soldering is required to get them replaced, yes.
Finding those button is hard. The easiest way is probably buying a broken (donor) motherboard and get them from there! Sorry.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Larry Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 35
总计 269
