跳转到主内容
加入维修社区 - 创建账户
Google Pixel 7a 是 Pixel 7 系列中的经济型机型。Pixel 7a 于 2023 年 5 月发布,在 Pixel 6a 的基础上增加了面容解锁、8 GB 运行内存、大幅升级的摄像头和无线充电功能。
Restocking of the battery
Hi there,
Got a swelling battery, was able to remove it with your tutorial before it gets worse, then wanted to buy a replacement one but you're out of stock.
Do you know if you'll be able to restock or is itgoing to be a long time shortage. Seems a stupid question but in France google dont do the battery replacement, and i dont know if it's due to a mass shortage.
Thx a lot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Swelled battery cannot be recovered, it's depleted completely. If you can't find a spare part, temporary solution may be using universal battery with similar size. It will reduce the capacity and maybe require some supports to hold the battery, but device will work. Sometimes you must take a controller from an old battery, if it refuses to start, and change only bank of the battery.
完成的
添加一条评论
2个答案
已选择的解决方案
@seeyounexttime that is a question that only the iFixit associates can answer. Most of us on here are volunteers and not directly connected with the business iFixit. You can get in touch with iFixit by using the customer service form
这个答案有帮助吗?
得分 3
添加一条评论
Hi @seeyounexttime
Search online for GP5JE battery France to find suitable suppliers if you can't get one from ifixit within a suitable timeframe.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rerholl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 205
