跳转到主内容
加入维修社区 - 创建账户
Logitech Lift 人体工学鼠标。有黑色、白色和粉色可选。
Left click button does work inappropriately,
Hi
I had used it around 10hrs every weekdays over two years, it is quite a long time use for daily basis because I am full time a drafter and designer. It started not reacting often with the left click button. yeah sometimes work sometimes not.
I've just replaced it with another new lift but if I can fix it, would glad.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
same for me. its a pity, i will reorder new one, but itl sure happen again. i didnt use it that much. but it happened after 2 years too
由完成的
Right button is glitching for me. Purchased Aug 22.
由完成的
添加一条评论
2个答案
最有帮助的答案
@hyundongsung check your mouse and see if this is a mechanical or electrical issue. Use something like this teardown Logitech Lift 拆解 to work on it. Check the plastic parts, the ribbon cable as well as the switch board. Let us know if you find anything that looks odd. Sometimes the top of the switches get wore down and the button does not reach deep enough to activate the switch. Adding a small piece of felt to the top of a switch can restore that function. If not, simply check the switches for function with a multimeter and see if they close the circuit when activated.
这个答案有帮助吗?
得分 3
添加一条评论
Disassemble it and resolder the left mouse micro switch. There's a many different suppliers, but average micro standard is universal. You can replace this with soldering iron or station.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hyundong Sung 将永远感激不已
浏览统计数据:
过去 24 小时: 20
过去 7 天: 92
过去 30 天: 354
总计 3,128
