跳转到主内容
加入维修社区 - 创建账户
Xiaomi Redmi Note 10 是小米于 2021 年 3 月发布的安卓中端智能手机。它配备 6.43 英寸 AMOLED 显示屏、4800 万像素主摄像头、侧边指纹传感器和 5000 mAh 电池,搭载骁龙 678 处理器。
May phone not charging
Not charging
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
Not charging
由完成的
@sam46889 have you already checked what I suggested in my original answer? what was the outcome?
由完成的
添加一条评论
1个答案
@sadnahda you are really not giving us a lot of info here! You need to consider to letting us know if anything happened to your phone or if it just stop charging. It is always helpful if you at least tell us what you have tried and what you have checked.
Well, let's start at the beginning :-)
First, you want to check your charger. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get an ammeter and see if your phone draws any amperage from the charger.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. Measure the voltage on your battery connector with the charger plugged in. You should get around 4.2V If you do not get this voltage If you don't get that voltage check your flex cable coming from the charging board. Make sure it is seated properly and does not have any tears or other damage on it. Your phone has a separate charging board that could be faulty. Consider replacing that.
To work on your phone use something like this video since iFixit does not yet have a guide for that,
这个答案有帮助吗?
得分 0
3条评论:
what if my battery shows around 3,6 v?, i have similar problem to person above, additionaly my phone sometimes popped up overheating popup, whe i ran many apps at one time
由完成的
@jan54210 the 3.6V is a bit low and it's the battery voltage. Your voltage should be higher at the battery connector. If the voltage does not increase when you measure it and connect the charger, you know the issue is either with the charging board or the PMIC on your board. Let us know what you find out. Common issue in your case could also be a bad battery.
由完成的
@oldturkey03 i created my own question, a lot mor detail there: phone not charging when plugged
由完成的
添加一条评论
添加你的答案
Sad Nahda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 50
总计 546
