跳转到主内容
加入维修社区 - 创建账户
通用汽车旗下 GMC 品牌售出的 C/K 皮卡车(包括 GMC Sierra)的维修指南与支持。
How can I fix or replace dash gauges?
Update (09/06/25)
@oldturkey03 Yeah it's a 94 GMC Sierra k1500 .
Seems oil pressure gauge(which I changed few years ago/failing to start) started too be erratic, year later or so the temp gauge goes rt too hot when running a few seconds, (pump replaced years ago, coolant good and no overheat). I changed sensors/wires (two), cleaned MaP sensor, checked grounds, found one broken but had no effect when connected. Didn't replace thermostat yet but have it, my guru says it's likely gauges going, there's motors in them that die off, short of tearing things apart thus breaking clips etc, what else is good or how to take out the cluster and replace it or gauges etc on the very cheap low expense end.
Seems The air/fuel mixture due pcm being told it's running hot (which happened years ago w broker fan belt) causes choking when stopped like it's timing is off-rumbling sensation. Worried about damaging worse then already may have driving
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@glentrs what exact year and model is your Pickup?
由完成的
添加一条评论
1个答案
已选择的解决方案
@glentrs I'd remove the instrument cluster and take a look at the back of it. See if there are burned/corroded traces etc. To remove the cluster use the service manual page 262. You can now download it from this page 1988-1998 GMC Pickup under the Documents Tab. For a more in-depth information about your cluster, look at the 1994 CK Truck SM that you can get on the same page. Check page 1280 in that manual.
Once you have the cluster out turn it over and take some pictures. Let's see if we can find anything odd looking on it.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
1条评论:
Ok OT ! I need a few days to get car running good so I won't be without. THANKS for the leads !
由完成的
添加一条评论
添加你的答案
Glentrs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 310
