跳转到主内容
加入维修社区 - 创建账户
针对2025年4月发布的 Google Pixel 9a 智能手机的维修指南、拆解说明及故障排除信息。
Screen glass replacement without pulling screen
I have a crack in the screen protection glass and a replacement for that already on the way.
However, I cannot seem to find a guide for glass replacement only. Is there a chance I can get the original glass off without pulling out the whole screen first?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@hannesreisinger nope. You will have to remove the display. After all you will need to heat it up and fit the cutting wire between the display and the glass etc. You also need to re-adhere the glass with some (L)OCA etc. Not something you can do on an installed display assembly.
You do realize that this is not an easy task and will need a lot of practice to be successful. I am not saying you can't do a glass only repair but pointing out that there are many pitfalls.
这个答案有帮助吗?
得分 0
2条评论:
Oh boy that sounds like something way outside my comfort zone. Cutting wire is the only option to separate the glass?
I guess I should at least have another screen at hand when attempting this... Thanks for the feedback!
由完成的
@hannesreisinger yup. Something like a 0.1mm wire is the common tool for that :-) I agree. Get a new display. I know they are way more costly than the new glass but replacing the complete display is still easier then a Glass-only repair.
由完成的
添加一条评论
Buna am.un pixel 9a display merge dar sticla e crăpată se poate schimba doar sticla și cat costa Mulțumesc
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hannes Reisinger 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 68
总计 1,303
