跳转到主内容
加入维修社区 - 创建账户
Phone temperature too low
What can I do to solve the problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@itsserge most common is actually a failed sensor on the ribbon cable from the daughter board to the main board. Replace that first. If that does not work, then this could be an issue with the battery or the daughter board. You can replace those and see if that fixes the error. Most common is actually a failed sensor on the ribbon cable from the daughter board to the main board. Replace that first. Let us know what you find out.
Since iFixit does not yet have a guide for this, use something like this video
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Its Serge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 144
