跳转到主内容
加入维修社区 - 创建账户
三星 28 英寸 4K 超高清显示器。型号 #LU28E510DS/ZA。
Guide to remove front panel layer
I have a bug that crawled behind the lcd front panel layer and died. Is there a guide on how to remove the front panel layer to dislodge the bug?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@jameshigh you will have to completely disassemble your panel. for that you have to tear down your monitor. There are no guides for that.
You can use the guides from here Samsung U28E510 to get into the monitor. Then remove all the boards and check the panel. There might be a removable frame. If so, then disassemble it by removing the frame. There should be a few diffuser sheets etc behind the actual display panel. Keep those in the original order and direction that they are in. Otherwise you will have display issues after.
Post some good picture of the actual panel once you removed all the boards etc. That way we can try and assist you further with this. It's a lot of work for a bug. It might just be easier to leave it where it is and try to live with it :-).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
James High 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 33
总计 239
