跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot SX530 HS 于 2015 年初发布,是一款支持 Wi-Fi 的超长焦相机。这款相机的重量不到一磅(约 450 克)。可通过型号 pc2200 进行识别。
E42 Error message appears when powered on
The camera powers on, but a yellow light flashes and none of the functions work. An error E42 appears on the screen. I have to remove the battery to shut it down. I've tried a different battery and different memory card. What is an E42 error? What will it take to repair it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thank you for your response. I tried all the methods in a video found in the link. After a couple of days of trying different things, suddenly the camera started working again. I don't know what method worked, but it's fixed. Thank you for the information.
完成的
添加一条评论
1个答案
已选择的解决方案
@marksalvatore the E42 is usually indicative of a lens error. If your camera lens can't extend or retract then your camera will display a E42 error. Try the ideas from here. Should that fail, you may have to replace the lens. For that use this guide Canon PowerShot SX530 HS 镜头更换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mark Salvatore 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 28
总计 420
