跳转到主内容
加入维修社区 - 创建账户
沃尔沃首款出口至北美的前轮驱动车型
Radiator Fan not working.
How can i test my Volvo Radiator Fan 1994 volvo estate 850 T5 radiator fan to make sure it is working correctly.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
mike, you can disconnect the fan motor plug from the relay, and supply power and ground to the fan motor directly. If the fan runs, you probably have problems with the relay or the temperature sensor. The temp sensor is just below the thermostat in the lower thermostat housing near the power steering pump. The attached diagram show you the wiring for our Volvo> Hope this helps, good luck.
这个答案有帮助吗?
得分 2
3条评论:
Thank you so much oldturkey 03, the radiator fan is now working
由完成的 分享
Thank you so much oldturkey 03, the radiator fan is now working,you are magnificent.
由完成的 分享
Thank you for accepting my answer and you are welcome :-)
由完成的 分享
添加一条评论
添加你的答案
mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 29
总计 8,645
