跳转到主内容
加入维修社区 - 创建账户
Samsung 2021 年发布的旗舰智能手机 S21 Ultra 的维修与拆解信息。也称为 Samsung SM-G998U1。
Screen failure after battery replacement
I did what I thought was a near-perfect battery replacement following IFIXIT instructions. The phone worked and I used it for the evening. Put it in the charging cradle overnight and I awoke to a dead screen. Phone still clicking as if working just nothing to see. How can my repair have caused a delayed fault like this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@christophe62605 a battery change should not be the cause for this. Always double check your work. Make sure that all cables are properly reinstalled and seated. Check the connector for any bend or broken pins. Let us know what you find.
这个答案有帮助吗?
得分 1
添加一条评论
Well,I personally have been repairing cellphones, tablets and electronics for 10 years or more now and the one thing I know is that the adhesive on the battery in cellphones is a demon that puts up one hell of a fight my friend.yiu should not really do this to get the battery out,I have done this myself..if you used something like a thick credit card or something like that to help pry the battery out due to the insanely sticky devil adhesive,you are also pushing on the backside of the LCD/screen whatever you want to call it. If not extremely careful you will definitely damage your LCD... Everything will still work except for your display. Your display may flicker or go White or whatever it does,it's just not correct and it's obvious, kinda like a cellphone that mysteriously stops having a functional display overnight... Im just messing with you. It only takes a little bit of pressure on a LCD to damage it. Do check your connections though could be a ribbon cable that you didn't close the lock on or another connection somewhere along the path of repairing the cellphone. But if you did happen to accidentally apply pressure to get the old battery out im going to say start there and be done with it. Good luck my friend, you got this. Never give up, never surrender,keep pushing forward!!!
Also I like to tell people this,byou might as well try to repair it,I mean it's already broken what's it going to get More broken??? Really?? Get out of here..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christopher Browning 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 52
总计 539
