跳转到主内容
加入维修社区 - 创建账户
interior lights flashing all the time
About 6 months ago my 2011 f250 6.7 interior lights and cab lights started flashing at the same time the pats system started acting up saying key not programed now ignition sometimes won't shut off the engine I have to pull ignition relay
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@michaelran54368 the flashing interior lights and cab lights are usually an indicator that the BCM needs to be reprogrammed. The BCM also controls your key program. Looks like your BCM does need to be either reprogrammed or replaced. The right OBD scanner for your vehicle might give you more detail.
这个答案有帮助吗?
得分 1
1条评论:
I have a snap on verdict scanner only codes im getting is for a communication issue due to low voltage and that's from when the ignition doesn't want to shut the truck off usually when that happens I have to pull the ignition fuse and disconnect battery and only then will everything work again
由完成的
添加一条评论
添加你的答案
michael rankin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 453
