跳转到主内容
加入维修社区 - 创建账户
Dell Latitude E5570 的维修信息和故障排除。这是一款 15.6 英寸商务级笔记本电脑,搭载第六代 Intel Core 处理器,于 2016 年发布。
Black screen of death
So when I turn on my laptop I get greeted with a black screen, some trouble shooting I have done it trying to reinstall windows (I still saw black screen), when i press caps lock nothing happens, when I try to open bios nothing happend, i have tried reseating ram, using a differant hard drive, doing a hard reset, took out the cmos battery then put it back in, tried plugging it into moniter with hdmi and vga, nothing works,
Any help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Does the screen turn on but not show anything or can you see the backlight on?
由完成的
@uptempoguy the backlight is not on at all. the screen is copletely black, same as when its turned off
由完成的
添加一条评论
1个答案
@heathbrown43963 check your backlight (most likely not the issue sine you also have no pictures on an external monitor). Turn your computer on and in a darkened room, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
It is possible that this is a bad BIOS. You may need to consider reflashing it. Of course, there is also a possibility that this is a failure of your GPU circuitry on your motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Heath Browning-Davies 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 24
总计 344
