跳转到主内容
加入维修社区 - 创建账户
本页面是 HP ProBook 640 G3 笔记本电脑的综合资源库,提供基本产品信息和详细的维修帮助。用户可以查找针对常见问题的故障排除指南,如设备过热、设备运行缓慢,以及针对电池、屏幕和内存等组件的维修指南。页面还包含该设备的“技术规格”,包括其显示屏、处理器、内存、存储和接口的详细信息。最后,“背景与识别”部分提供了关键的产品背景信息,并帮助用户确认其设备型号。
Why my pc wont start
When i power on my pc lights on, a black screen with continously beep sounds.How am i suppossed to fix it??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Beep sounds usually come in a repeating sequence, try counting them; there's usually a slightly longer gap between groups. At some point you'll find they're repeating, and that's when you have the "beep code" that can be looked up for troubleshooting. As an example, you might find they're repeating in a pattern like 5-3-4-1 or something similar.
完成的
dvd piyar not open
完成的
@assadnadeem Assad, please start your own question and be sure to categorize it as best you can and include the manufacturer and model number of your player.
Also, you need to elaborate on what the issue is. When you say "open", do you mean the door to load the disc won't open, or do you mean it won't turn on? The better description you give of the problem, such as when it started and what you've tried so far, the more help we'll be able to offer. What you've said so far is unanswerable; there's just not enough information for us to assist you.
完成的
添加一条评论
1个答案
已选择的解决方案
@sir_dm a continuous beep is common with BIOS issues. Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life. You could also try to disconnect the battery.
Most common issue are drive and it is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
As you turn your computer back on tap the F10 key. This should load the BIOS setup utility.
Press F9 to load defaults.
Press F10 to save and exit.
Let us know what you find out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel Majura 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 30
总计 426
