跳转到主内容
I see many fine horizontal lines across my Chromebook display.
In the last few weeks there are many fine horizontal lines across my Chromebook display. They are primarily at the top of the Chrome browser screen. The view of the top of the Chrome windows are very distorted. There is no physical damage to either the Chromebook or the display.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
WIthout photos, we have to assume a bit. This is generally going to be a cracked LCD or a TAB failure. THAT SAID: Without a model, we can't locate the screen -- but in lieu of that if you look up your model Chromebook and LCD you can probably locate the LCD relatively quickly. Most Chromebooks do not have expensive LCD replacements as many of them are 11-13" affairs with cheap VA iDP LCDs, which tend to be relatively cheap to replace since many of them use cheap Innolux displays or VA LG LCDs.
That said, depending on the age of the Chromebook and it's EOL status, the cost of a panel may be near the cost of a newer model. A lot of the old Chromebooks only got 3-5 years of updates and deprecaitated off of a cliff, making any repair a "mechanically totaled" issue. The newer 10 year ones hold up better but Google's SW update policies still mean you need to check against how much life it has left before being deemed EOL: Chromebook AUP list
If it's still workable short of a TAB failure and the panel cost vs unit is very close to the same price I'd see about a parts unit with MDM and get the panel that way - assuming the model isn't near EOL.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Steve McCabe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 23
总计 23
