跳转到主内容
加入维修社区 - 创建账户
第一代,基于福特 C1 全球平台打造。
Check engine light cod. P01031
Se enciende la luz de check engine con cod. P0132
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@manuelniebla here are the possible causes for the P0131 code:
Front H02S malfunction Connector or terminal malfunction
Open circuit in wiring harness between front H02S terminal A and PCM terminal 2AD
Short to ground in wiring harness between front H02S terminal A and PCM terminal 2AD
Open circuit in wiring harness between front H02S terminal B and PCM terminal 2Z
Short to ground in wiring harness between front H02S terminal Band PCM terminal 2Z
PCM malfunction
Use this part of the workshop manual P0131 P0132 Diagnostics to do a deep dive and to diagnose which part may actually cause this error. Most commonly issue are bad Oxygen sensors. Here is the location of the sensors
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Manuel Niebla 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 18
总计 205
