跳转到主内容
加入维修社区 - 创建账户
一款全新的 Passat 基于大众集团 B5 平台,于 1998 年在北美上市。
Charging problems with battery
My battery won't charge
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@shirleylar63859 let's start off by clarifying what you have checked. Have you checked your battery? Have you checked your alternator? Use a voltmeter and measure the battery voltage between the positive and negative post. It should be around 12V Next, with your Passat running measure the voltage between the positive and negative post. What voltage do you get (expected is around 13.5V to 14V DC). If you have that voltage, it is most likely your battery. If you do not have that voltage, it could be your alternator. Let us know what you find out.
这个答案有帮助吗?
得分 1
添加一条评论
well, you must start by doing something and letting us know what you did.
Your question is like my car won't run. What's wrong?
Start by taking it to AutoZone or Advance Auto, They can check the battery and alternator.
That alone will likely get you an answer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shirley Larson (Squirrel) 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 14
总计 173
