Samsung S8 active overheating
Everything turned on normally, heating at around 50°C on the motherboard whilst charging
here are the temperatures, hope y'all can help me
You need to open up the phone and see the component that causing the heat using a thermal camera. Sorry but I guess you need to take it to a technician.
这个答案有帮助吗?
Heating more than normal while charging is a sign your battery needs replacing.
If the battery over heats, it will obviously heat a lot of other things since it covers a large area.
Do a battery test and see if that gives a clue.
这个答案有帮助吗?
@jamesleebron connect an ammeter between your charger and your phone. See how many amps it is pulling. This can be an issues of the charging circuitry (bad PMIC, failed Battery controller etc.) Make sure that you have a good USB cable and that your charging port is in good working condition. Check the pins for corrosion etc. After that you will have to open it up and check for any damaged or disconnected components. A new battery is always advice but do not ignore the charging board Samsung Galaxy S8 Active 子板更换
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 168
