跳转到主内容
The Huawei Watch GT 2e was released on April 20, 2020. It features an AMOLED 1.39" 454 x 454 pixel display, 4 GB 16 MB RAM, GPS, bluetooth, accelerometer, gyro, heart rate, barometer, compass, and SpO2 functionality.
1 个问题 查看全部
Black screen after swimming pool
Hello
I have a GT2 Pro, this morning after swimming the watch went off.
The pulse sensor lit up, I managed 2 times to display the screen from the application (charge 43% displayed) but now everything remains black, screen, sensor and no longer vibrates.
What is your opinion on the H.S display or the motherboard?
thank you in advance for your feedback
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @lamadelon
Could be either or both. You won't know until you open it up and check to see what's wrong.
It does seem too coincidental that the watch failed after being immersed, so presumably its waterproof integrity has failed somehow
If there is evidence of corrosion then you would need to dis-assemble the watch and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here are some links that may help.
Electronics Water Damage
Huawei Watch GT 2e repair guides
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the watch might possibly work correctly again.
If this process seems too daunting, take your watch to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
FYI, here are some links that may be of interest, regarding Huawei wearable products water resistance ratings and definitions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
LA_Madelon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 13
总计 27
