跳转到主内容
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
Screw issue , not coming out
My PSP back cover screw not coming out .
It is moving on it’s position plus not fixing
at clockwise .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi there!
Okay, is the screw still good? Or totally stripped?
If it's not stripped, I assume it's broken inside and this will not be easy. You need to block somehow the plastic which is turning together with the screw. So, take out the other screws and carefully open it a bit, so that you can grab the plastic and take the screw out.
If you can share some photos with us, it would be great! Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Divyarth Singh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 28
