跳转到主内容
加入维修社区 - 创建账户
Nokia 1208 是一款由芬兰诺基亚公司在其 Ultrabasic 系列下销售的低端 GSM 手机。Nokia 1208 于 2007 年 5 月发布。
Charging pin not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Wht ans btao
由完成的
添加一条评论
1个答案
@manish36089 it's a bit old but just came across this on Answers. Anyhow, start with a new battery. You did never say how old the battery was etc. Next you want to make sure that your charger is working. It's a barrel connector with a negative on the outside and the positive in the centre,. Check the voltage on that with a multimeter. It should be somewhere between 3.6V and 4.2V.
If all that is ok then you need to think that this may be caused by a bad charging port on the motherboard. Disconnect your battery, plug the charger in and measure the voltage on the battery connector. It should be in the same range as the charger voltage was. Now it's time to disassemble your phone.
For that use the Nokia 1208 Lvl 1 2 SM and go to page number 11 to start. Next use the QUICK TROUBLE SHOOTER - CHARGING Nokia 1208 Quick Troubleshooter Charging
(page 16 in the same SM) to measure the components listed. Make sure that those are okay.
Now if all of that checks out and you need to do some further troubleshooting. You will need to check the circuitry for the battery charging IC (LITTI). Use the Nokia 1208 Lvl 3 4 SM and start off by checking the Troubleshooting flowchart for the "Phone does not switch on" page 55 of the SM
Anything past that will be related to the circuitry on the motherboard. Now you will need Nokia 1200 RH 99 100 Schematics and the right tools and skills to check the charging circuitry.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
manish 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 226
