跳转到主内容
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 个问题 查看全部
问题已关闭
Does anyone know how to fix the red ring of death
Does anyone know how to fix the red ring of death.If anyone knows how just let me know
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Marco, there are a couple things you can do. First one would be to try this guide for using this this kit. Second, you could try to reflow your IC's by following this guide. Hope this helps, good luck.
Xbox 360 Red Ring of Death Fix Kit图片
产品
$29.99
指南
难度:
困难
45 minutes - 1 hour
Xbox 360图片
指南
Reflowing Xbox 360 Motherboard
难度:
困难
1 - 3 hours
这个答案有帮助吗?
得分 2
添加一条评论
It's a pretty simple fix as long as you're careful, patient and relatively organized.
这个答案有帮助吗?
得分 0
添加一条评论
Give it to a local pro! it will save you the cost and headache, it needs to be done properly with 3000$ machine not a hair-dryer or whatnot (trust me, I fix ppl's utube stuff-ups almost everyday, and it's a lot harder after they have messed it up following an internet tutorial!)
Just have a look in classifieds or computer stores for a PROFESSIONAL (not some back-yard-er with a paint-stripper or someone selling you 2$ worth of screws for 30$ and telling you to remove your x-clamps and drill thru ur chassis -good way to perma-warp ur PCB) Ask them first what their qualifications are& what equipment they plan to use, or you may end-up with a temporary fix or worse.
A decent pro should charge between about 100 and 50$ (for a professional reflow - sufficient in about 80% of cases if done correctly, a reball is more permanent, but carries a small risk& an extra cost) and they should offer warranty
Good Luck :D
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,009
