跳转到主内容
A gaming PC is a personal computer specifically designed and optimized for playing video games.
Why is my bios beeping in my pc
So I built a pc 4 months ago and the last week I changed my rams and the rams I originally put in my pc were burnt and since then my bios or something in my pc is beeping and It turns on but my monitor shows no signal and I did everything like put my old rams back and it was still beeping I put in my new rams still beeping
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
We will probably need some more information to get this sorted. Beeping is usually a sign of a RAM error, but not always. Some specs for your PC will help especially which motherboard you're using.
Burnt RAM sounds problematic, but it will help to see exactly what you mean. Can you add some pictures of this damage to your question?
完成的
@galrobert how did this "I originally put in my pc were burnt" happen? How did you "burn" your RAM? Since you only get beeping on start up, the issue seems to be your BIOS, possible the RAM difference. We will need to know what motherboard you have and what RAM you used as replacement. You did verify that you have compatible RAM modules, correct?
Use this guide 在已经存在的问题里加入图片 to add images to your Question.
完成的
Burnt literally having burn marks or you mean burned out like simply stopped working?
Beeping is the traditional way motherboards indicate errors.
Much better if you can provide your motherboard's model and some pictures of you new and old ram sticks.
完成的
Yeah having burnt marks and Im not at home but I can tell you the type of motherboard I have in it and the ram sticks if you need
完成的
@galrobert
Knowing the motherboard make and model number and also number of beeps (pattern?) would definitely help you further.
完成的
添加一条评论
1个答案
It is possible that one of the diodes or resistors was damaged when you installed the RAMs and they burned. The best thing to do is to test the resistance and voltage of all parts of your motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gal Robert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 37
