跳转到主内容
加入维修社区 - 创建账户
2018 年发布的 Acer Predator Helios 300,可通过多个型号进行识别。大多数指南适用于所有型号。
Graphic ic problem motherboard dead
Motherboard dead because of Graphic ic heat not turning on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@rameshwarp48401 how do you know it is your Graphic ic (which is your GPU)? You really need to let us know what and how you have checked this. You are also not saying if anything has happened to the laptop prior to this. If so, you want to give us the model number for your motherboard. With that, we can try and find the schematics so we can possibly help you to check your motherboard.
By the limited description you have given us, I would expect this board to be a Compal LA-921P. Let us know the complete model number for your computer so we can verify the board.
You need to check and see if you have video signal on either the HDMI connector or the eDP connector. If you have no video on HDMI it could be an issue with the NVidia IC or the VRam. If you have no video output on either the HDMI or the eDP it is most like an issue with the GPU but you have to make sure you check the GPU power first. Here is the schematic for the LA E921P mother board.
这个答案有帮助吗?
得分 1
添加一条评论
if the motherboard is dead then there is very little that you can do unless you have an identical motherboard somehow
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rameshwar Pardeshi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 209
