跳转到主内容
加入维修社区 - 创建账户
2019 年 9 月发布,型号为 J8210、J8270、J9210、J9260。
Mobile is not working
My mobile is not turning on and not charging and also pink line issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@abdulahadq78484 if it is not turning on how do you know it has a pink line issue? That line issue will most likely require you to replace the screen.
As for the rest, first you want to check your power supply. Make sure it has the proper voltages. Check to make sure that the connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this makes a difference, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Adding images to an existing question - iFixit Repair Guide
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abdul Ahad Qureshi 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 17
总计 218
