跳转到主内容
加入维修社区 - 创建账户
广受欢迎的 Apple 迷你桌面电脑,2024款 Mac mini 的维修指南,拆解信息和疑难解答。该机型使用 M4 或 M4 Pro 处理器,最低配有 16GB 统一内存。
How could I extend the power button cable?
I am working on an application that would involve me needing to extend the power button as the Mac Mini would be unreachable. Can you help me identify the power button clip and a potential way to extend the cable further?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Has anyone found what connector is used? If we knew what connector was used (and could get a couple) It would be easy to wire an extension and move the power button wherever.
由完成的
添加一条评论
2个答案
最有帮助的答案
Depending on what your application is, I’m assuming it’s to restart as the process hung. If that’s the case then just leverage the AC power cord by placing a line switch within its path, as an example a power strip. If the application is just doing a presentation type of loop that would work. You could also setup a watchdog process from another system to manage the power strip if it has a remote control option.
这个答案有帮助吗?
得分 1
添加一条评论
@matthewtietje if by power button clip you are referring to the connector, we don't have that information just yet. Just like all of those connectors you can most likely remove it from the actual cable. We would need to see a close up of that connector to determine how to take it off. After that its straightforward, just extend the wires but either or using a cable connector to connect a longer cable (however long you need). Then connect a SPST normally open pushbutton switch to the terminals of the extension.
这个答案有帮助吗?
得分 0
1条评论:
Thanks. You can see the cable being unclipped in the teardown. Hopefully someone will identify it in the near future!!
由完成的
添加一条评论
添加你的答案
matthewtietje 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 816
