跳转到主内容
加入维修社区 - 创建账户
Panasonic Lumix ZS50(北美地区)或称 TZ70、TZ71,是一款发布于 2015 年 3 月的小巧轻便个人旅行相机。该相机配备了 Leica 长焦镜头(30 倍变焦,24-720mm)、增强的弱光感光度、内置取景器以及 1210 万像素的分辨率。
About problem while opening Lens Assembly
Can you give the pin details of the 6 pin ribbon flex cable inside the lens assembly that goes inside to the camera shutter in the DMC-TZ70, I accidently tear up that flex cable (while trying to clean the front lens), I want to connect it by jumper wire as those flex cable is not available in my country. ( upendradawadee.gmail.com; Nepal)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
@upendradawadi that is one elusive flex cable. It's pretty difficult to fin out anything specific. I added the service manual to this page Panasonic Lumix ZS50 (TZ70, TZ71) under documents. It looks like the shutter flex connects to the Lens Flex cable. There is nothing specific in the schematic other than the LENS DRIVE BLOCK DIAGRAM on page 54, which does not give a clear indication what those points are. You may get some answers from the schematic and the Lens Flex cable on page 84.
这个答案有帮助吗?
得分 1
1条评论:
I somehow manage that cable from old camera and lens assembly problem solved. But to clean the zoom Lever switch I opened the TOP PCB Unit, cleaned it and reassembled the camera, everything is done finely, now the camera work as before but suddenly I found the Flash is not working. But the camera system does not show any message on display about faulty Flash, so what may has happened in this TZ70 camera? Can you suggest possible step to finding out the fault??
由完成的
添加一条评论
最有帮助的答案
@upendradawadi Can you show us a picture?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Upendra Dawadi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 36
总计 425
