跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 7306 2-in-1 Black 是由戴尔制造的一款二合一笔记本电脑。规格: Inspiron 7306 2-in-1,第 11 代英特尔(R) 酷睿(TM) i7-1165G7 @ 2.80GHz 处理器,16 GB DDR4 内存 512GB NVME 固态硬盘(不可更换)
Motherboard Crashed after tech “attempted” to diagnose.
Long story short, my laptop was losing its charge. After getting it diagnosed, I was told it was at the end of its life. If it doesn’t turn on, is it still possible to retrieve its stored data? TIA
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @jalenahood, there are some ways you can try.
Ideally if the computer is able to boot up to windows,
I would suggest to check and backup bitlocker keys.
https://www.dell.com/support/manuals/en-...
Based on the battery replacement guide, on step 5,
i can see the there is nvme ssd.
Dell Inspiron 7306 P125 电池更换
you can consider getting this usb enclosure
https://www.amazon.sg/ORICO-M-2-Enclosur...
这个答案有帮助吗?
得分 0
2条评论:
I tried a battery replacement. It no longer turns on. After the replacement it slowly lost its charge and plugging it in does nothing.
由完成的
@jalena
try disconnecting the battery from the laptop and power on the laptop with just the power adapter.
does it works?
由完成的
添加一条评论
添加你的答案
Jalena 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 163
