跳转到主内容
Dell Inspiron 7306 P125 Battery Replacement
你所需要的
  1. Dell Inspiron 7306 P125 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 7306 P125 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off the laptop with the power button and close it.
    • Disconnect any power sources from the laptop.
  2. Dell Inspiron 7306 P125 Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 7306 P125 Battery Replacement: 步骤 2 中的图像 2,2
    • Use the Phillips #00 screwdriver to remove the seven M2x4 screws from the back panel of the laptop.
  3. Dell Inspiron 7306 P125 Battery Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 7306 P125 Battery Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 7306 P125 Battery Replacement: 步骤 3 中的图像 3,3
    • Grab a corner of the back cover or use a spudger to lift the cover.
    • Pull the cover up around the edges until it is completely removed.
  4. Dell Inspiron 7306 P125 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 7306 P125 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the three tapes on the left, middle, and right of the battery.
  5. Dell Inspiron 7306 P125 Battery Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 7306 P125 Battery Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 7306 P125 Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the three M2x3.5 screws that have a screw icon above them with the Phillips #00 screwdriver
    • Do not interact with the object located to the left of the middle screw.
  6. Dell Inspiron 7306 P125 Battery Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 7306 P125 Battery Replacement: 步骤 6 中的图像 2,2
    • Pull the battery cable towards the direction of the opening.
    • Do not pull the cable upwards.
  7. Dell Inspiron 7306 P125 Battery Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 7306 P125 Battery Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 7306 P125 Battery Replacement: 步骤 7 中的图像 3,3
    • Insert the new battery. Align the holes of the screwdriver with the center object.
    • Apply the tape from the wires to the battery once more.
    • Ensure that the cover snaps into place when closing the back cover.
结论
另外一个人完成了本指南。
Arturo Gonzalez
于03/29/23注册
172 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-73, Briggs Spring 2023 CSU Los Angeles, Team 2-73, Briggs Spring 2023 的会员
CSULA-BRIGGS-S23S2G73
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 81
总计 667
