跳转到主内容
加入维修社区 - 创建账户
主要供裁判使用的无线通信设备。
Loose connection inside the rectangular rubber-coated case
Where would I start if I wanted to take this apart and re-solder it? Obviously would prefer to avoid any permanent damage. I've tried sliding a knife around the edges (there's a slight ridge where what appears to be two halves were pressed together), but I'm guessing I need heat and/or some kind of solvent. Anyone have experience taking apart weatherproofed / sealed electronics?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
@miketexter post a couple of well -focused images of the "rectangular rubber-coated case" with your Question. that way we can see what you see and hopefully assist you further. 在已经存在的问题里加入图片
完成的
@oldturkey03 done, thank you for that tutorial :)
完成的
添加一条评论
1个答案
最有帮助的答案
@miketexter that looks like it's very well glued together. If this would be mine, I'd take an exacto knife (or a razor blade) and cut through the seam. After completing the repair, I'd use some silicone rubber glue to reassemble the case.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mike Texter 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 16
总计 181
